48RE 2-3 flare shift
Old Jul 1, 2011 | 02:15 PM
MTDBJD's Avatar
Default 48RE 2-3 flare shift
06 5.9L all stock, 78000 miles
Under light throttle the 2-3 shift will act like it is slipping sort of like a clutch slipping in a manual transmission. If you put your foot in it a little bit it will shift fine. Dealer has adjusted bands, replaced valve body, did all PCM updates. Still have the problem. No heavy towing or programmers. Any ideas? Thanks
Old Jul 2, 2011 | 06:48 AM
merch131's Avatar
Default flare fix
yep.
it's the electronic govenor inthe tranny. upgrade to the gm style. ~$45
Old Jul 2, 2011 | 06:50 PM
MTDBJD's Avatar
Default ?
So you are saying the pressure governor that was put in with the new valve body is bad? Or does the GM one do something different?
Old Jul 3, 2011 | 08:11 AM
merch131's Avatar
does the same thing but more dependable.
look in thourghbreed diesel web site.
it's another weak point in the dodges.
there's also a screw you can acess while the pan is off to boost line pressure for firmer shifts.
just look around the web, you'll find info on it.
very easy fix/upgrade
Old Aug 14, 2011 | 09:33 AM
akhappyjack's Avatar
are you talking about the gm pressure control solenoid and what trans is it from? 4l60e or 4l80e, what web site? as my 06 ram is doing the same thing.i just put it in tow haul
which just raise's the line pressure
Old Aug 14, 2011 | 12:30 PM
merch131's Avatar
i can't access the place i got it from.
it was a brand name site to do with trany parts.
don't know what trany it came from either.
sure did the job for me.
i came down mt washington in 2nd gear at the bottom it started to do the flared shifting routine.
started to reshearch these sites and got what i needed.
try goggle 48 series tranny flared shifts or such.
Old Aug 14, 2011 | 03:50 PM
Default Solenoids
I went to that web site, it looks like a 4l80e pressure control solenoid with a cast housing that bolts into place where the oem one goes. If I remember right that is a pwm solenoid and yes the dodge one is a crappy design,there is a adjustment on top of the gm one but have never played with it
Old Aug 14, 2011 | 07:44 PM
dangerous1965's Avatar
Patc and e-bay have them. Did you try and adjust the band first?
Old Aug 15, 2011 | 08:12 PM
Default 2-3 shift flare
no I need to do it though. The problem I dealing with and it's not a problem is it actually will stack shift 2/3 2/3 under light throdle and it's just the design probably putting the new govener solenoid (GM) with a transco shift kit will clean it up
Kfohne21
10
May 12, 2022 10:13 AM
jeremiah1
Jul 21, 2015 06:35 PM
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
