stock turbo question
Old Jul 1, 2011 | 11:34 AM
snowboard3r411's Avatar
Default stock turbo question
i got got a set of used autometer phatom gauges and i hooked my boast gauge up and i only make 15 lbs of boast on my stock tubro is that right?? reason why i ask is cause i used to use a oil pressure gauge for my boast and made 20lbs
Old Jul 1, 2011 | 01:51 PM
KD93's Avatar
Depends on how much fuel you've got. I'd expect to see a bit more than 15psi if you've got no leaks and the turbo's in good shape. IIRC, somewhere in the vicinity of 22 - 25 psi is about right for a hopped up IP on a stock charger. The Phantoms are electric, are they not? Check your ground for the boost gauge unless they share one.
Otherwise, maybe there's a reason they were sold.
Old Jul 1, 2011 | 07:23 PM
crazy clem's Avatar
mine makes 25 mildly tweaked pump and measured at intake. banks boost gauge.
Old Jul 1, 2011 | 08:24 PM
backwoodsW250's Avatar
My truck run's around 30 lbs with a stock turbo, maxed pump, and 4 in down pipe. the exhaust seems to have gave me about 5 lbs extra by my snow performance display.
Old Jul 10, 2011 | 09:20 PM
Racermt's Avatar
My truck runs about 22 with pump work and 4" exhaust after the stock downpipe
Old Jul 19, 2011 | 11:16 AM
sootnsmoke's Avatar
Seems like my truck with completely stock engine, intake and exhaust makes for a barely audible turbo. Is that what others have found before moving away from a stock configuration? I get no black smoke and good acceleration but thought I would check.
Old Jul 19, 2011 | 01:58 PM
jdbigblue12v's Avatar
smoke doesnt mean anything except un-burnt fuel, which is better for the truck. my truck is stock exhaust but straight piped with a tweaked pump and star-wheel a half of a turn and i see smoke if i really step on it. im going to tune the pump til theres no smoke at all
huntman7
8
Aug 28, 2015 05:42 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
duramaxtuner
LB7 Performance
Dec 10, 2014 01:52 PM
GreenDieselF
Oct 20, 2014 02:05 PM
