Fuel plate Problem
Old Jun 30, 2011 | 12:38 PM
keeponcummin's Avatar
Default Fuel plate Problem
IS there a trick to getting the bolt that you take off with a flat blade screw driver loose? Iv tried everything and cant seem to get it loose. the other 2 bolts came loose easy. Its a 1994 Thanks
Old Jun 30, 2011 | 01:17 PM
dieselfury12's Avatar
Take a chisel and a hammer and make a head that a flat head screw driver will fit into and take it out and don't have to worry about puttin that screw back In
Old Jun 30, 2011 | 01:35 PM
South Tx Coal Roller's Avatar
Are you talking about the factory one that looks like a rivet? If so I had to use a chisel to get mine lose. Once you get it off do yourself a favor and replace it with a regular bolt. I believe the size is M6 x 1.0 threads and it's 16mm long.
Old Jun 30, 2011 | 03:30 PM
dezzrats's Avatar
I drilled a small pilot hole in the head and then used a hand impact driver with a square head bit. I don't want to talk about all the other stuff I tried before I got it out.
Old Jun 30, 2011 | 04:22 PM
Ok thanks guys!! Il let u know if i get it! I dont understand y they dont just use all regular bolts on it!! They just hav to make it a pain in the rear!!!!!!
Old Jun 30, 2011 | 04:29 PM
94 12valve's Avatar
cuz they didn't want anyone messing around with it when it was new
Old Jun 30, 2011 | 08:17 PM
turbo2332's Avatar
i never coult get a flat head or a hex bit to bite. i managed to get a long thin flat head horizontal..ish to the screw and tapped it with a hammer and get it loose
Old Jun 30, 2011 | 09:16 PM
Do u guys replace that breakoff bolt then??? Is it ok to go without?
Old Jun 30, 2011 | 09:53 PM
You don't HAVE to replace it but seeing that a new one is .25 or so I would.
Old Jul 1, 2011 | 03:52 AM
davo79's Avatar
I found the easiest way was a t18 torx bit on an impact driver smack her with a slugger an off she goes
