air dog 2 bogging truck down
Old Jun 30, 2011 | 08:42 AM
skyler1101's Avatar
Default air dog 2 bogging truck down
hey guys i installed my airdog 2 165 yesterday and im going to be installing my fuel pressure gauge today but from what the manual says i should be sitting at 15-17 psi right now but it seems like my truck has bogged down quite a bit and smokes alot harder since the install the truck seems alot slower and when i get off the high way after going like sixty the truck engine sounds like crap and sounds like its way overfueled almost like its gonna die ?? any suggestions?? i lost a lotta speed the truck seems slower now
Old Jun 30, 2011 | 09:50 AM
BACONBITSFORU's Avatar
Strange glad I waited to get mine
Old Jun 30, 2011 | 11:16 AM
RAW's Avatar
RAW
Get the gauge in ASAP to see what is going on, it's a MUST!
Old Jul 1, 2011 | 02:22 AM
skyler1101's Avatar
ok but i do not understand where the hell to even wire in at on the airdog?? for fuel pressure
Old Jul 1, 2011 | 02:50 AM
dukeboy_318's Avatar
you dont wire in to the airdog, you tap into the banjo bolt on the VP44 or the top of the filter head for the fuel filter.
Old Jul 1, 2011 | 05:25 AM
Lostnwalmart's Avatar
Try turning the adjuster counter clock wise to lower pressure and see if it runs better.
Old Jul 2, 2011 | 09:38 AM
skyler1101's Avatar
ok i have dont that lostnwalmart i should be sitting at 15 psi from what the manual says and i do not have the filter housing anymore for the truck i removed it and how do u tap into the banjo bolt i have all the quick connect fittings from the airdog on there?
I figured it out i had a leak in a gasket under theinjector lines but now i got fuel pressure gauge hooked up 25 psi at idle is my airdog running right if at wot it suclks me all the way down to 17?
Old Jul 2, 2011 | 04:37 PM
empty wallet's Avatar
25 psi at idle is way too high, you will smoke your vp... 18-19 tops, unless you notice it dropping to under 10 at wot, then go 20. Between 12-18 is a safe range for all times, less than 10 and more than 20 can be damaging to the vp44
Old Jul 3, 2011 | 04:45 PM
skyler1101's Avatar
how can it be damagin i dont get it?
Old Jul 3, 2011 | 07:27 PM
Too much pressure can damage the diaphram inside the pump.
