Only 1 cam bearing?
Old Jun 29, 2011 | 11:16 PM
kieron_kohlmann's Avatar
Default Only 1 cam bearing?
Is there only a front cam bearing in these engines?
Old Jun 30, 2011 | 12:55 AM
Chevy72's Avatar
Yep only one!! Seems kinda dumb huh?? If your other bores are messed up you can have them enlarged and install bearings. but for stock it's only got the front
Old Jun 30, 2011 | 05:59 AM
KD93's Avatar
Wow! Something seems wrong with that...
Old Jun 30, 2011 | 09:25 AM
1arock's Avatar
A lot of smaller and midsized diesels have no cam bearings JD engines for one have none. The cast iron block is pressure oiled and serves as the bearing surface. As long as you maintain some kind of oil pressure it seldom causes an issue, if you loose oil pressure and keep running the cam bearings are gonna be the least of your problems.IMHORocky
Old Jul 1, 2011 | 07:55 PM
It just seemed weird when i turned the block over to pull out the crank and noticed no rear cam bearing. it makes sense though since the cam turns half the speed of the crank, which is marginal compared to a gasoline engine.
wolfriver
Mar 23, 2016 10:18 PM
oznation
Jul 28, 2015 02:54 PM
W Vaughan
For Sale
Feb 10, 2015 06:29 PM
wpg6.5
Dec 9, 2014 10:20 AM
