Performance
Old Jun 29, 2011 | 09:33 AM
RollinCoal91's Avatar
Default Performance
I want to find a better turbo for my first gen so that my EGT's drop any suggestions? also if i get POD injections would that be a good injector to start with?
Thanks
-ian-
Old Jun 29, 2011 | 11:05 AM
forgasm's Avatar
d tech turbo from dieselpowersource.com i have a friend that put one on his gen one and it dropped egts 250 degrees and it spools faster than an hx 40 he had on and he is getting alot more power
Old Jun 29, 2011 | 05:59 PM
KD93's Avatar
It depends on how much money you want to spend. A compressor upgrade for your stock turbo will drop EGT's and give you more power. Is your truck an auto or manual. That will help a bit to advise on a better turbo. Also what plans you have for the truck power-wise and what you'll be using it for. Give us some more specific info and we'll be able to help you better.
As for the POD's, they are good injectors for the price. But IMHO there are better ones out there. Also, your stock injectors will support around 300hp, so you may not need to buy new ones anyway.
Old Jun 30, 2011 | 11:09 AM
jkidd's Avatar
POD's are the wrong spray pattern for both IC and non-IC. Its better to stay with the 145 spray pattern if you are IC. the stock non IC 89-91 will see only a slight increase from POD's.
I can get you 7x .0xx injectors in 145* or 155*. There are also cheaper options for the 145* IC engines.
Old Jun 30, 2011 | 03:39 PM
1STGENFARMBOY's Avatar
With everything in my sig except the 3 in coolertubz, P/S intercooler, 60 mm GDS upgrade my truck would blow buy 1600* and keep going, after i put on those three things on now it won't get past 1250* no mater what i'm doing.
pulling 18,000 on a goosneck 1250* is it. flat footing up to 100mph 1200* is it.
with that said if you have a 5 spd or a good tight converter it could go higher i just don't know.
Darwin
Old Jun 30, 2011 | 08:32 PM
i have a 5spd tranny, and if you could give me a list of things that you would do first or what you did first in your sig 1stgenfarmboy that would be great, and also i am going to use this truck for pulling trailers for longer distances and also as a daily driver, thanks a bunch!!!!
and jkidd i looked on that web sight and i saw that max mileage module it says it works with the 1988-2007 trucks how does it work on the older trucks?
Last edited by RollinCoal91; Jun 30, 2011 at 08:32 PM. Reason: Automerged Doublepost
Old Jun 30, 2011 | 09:46 PM
OK i'll try this ....
1. pump adjustments, idle screw mia, full travel, 1 turn from runaway, tune your AFC, 3/16 timming, 366 spring, denny T pin.
2. lift pump upgrade of your choice with gauge. as long as you can hold 8 psi or above your fine.
3. i have DDP 80 hp but 5-14's would be good to. (not pods)
4. BHAF, BHFF.
5. 4 in DP with big exaust, my truck already had a 16 cm housing.
6. I gutted my grid heater but it's not needed, i don't know if it helps or not.
with this set up it was very very HOT HOT HOT.
7. P/S intercooler, 60MM GDS, and Tim Worlines 3 inch stainless cooler tubz all went in at the same time, so i don't know whitch one helped the most.
but after these i hit the sweet spot cause it ain't hot no mo.
i can hold 39 psi boost.
Darwin
Old Jul 1, 2011 | 02:08 PM
KD93's Avatar
Darwin pretty much hit it on the head, except for one thing, and possibly the most important. GAUGES!
I know he just overlooked them, because he is nothing if not meticulous. At the very least a pyrometer is essential to keep an eye on EGT's, although if you're towing I'd be looking into boost, tranny temp., rear diff. temp., oil pressure, oil temp., fuel pressure, and coolant temp. as well. Unless you have gauges already...
Old Jul 1, 2011 | 04:07 PM
Does he really need a trany temp with a 5 spd...........
JK
Dar
Old Jul 1, 2011 | 05:20 PM
KD93's Avatar
