boost
Old Jun 28, 2011 | 06:30 PM
stinkyD's Avatar
Default boost
how much psi can a stock 1993 chevys head gasket withstand? head studs if im throwing in a hx35?
Old Jun 28, 2011 | 08:16 PM
turbo2332's Avatar
well the hx35 max is about 35lbs reliably. ide say the truck would probably be around 15ish give or take. are you gonna be givin her the fuel?
Old Jun 28, 2011 | 10:28 PM
Crazy's Avatar
15 psi is max for 6.5
stock can only run 8 psi or less you put program open up the exhaust
Old Jun 29, 2011 | 03:33 AM
stinkyD's Avatar
shooot! I NEED A 12v CUMMINS! use this 6.5 truck for camping!!!!! ...I NEED HELP: i got the stock borgwarner, stock holset RX, or this hx35 and i think this hx35 is gunna be too much boost.... (which one do i use?)
i bumped up the fuel a 1/4 turn in the injector pump, i guess i can increse if needed but will have to deal with the heat. rollin coal down the HWY out the hood stack but having the turbo lag and seal leak. want a better system also, ya know.
Old Jun 29, 2011 | 02:33 PM
Woody35's Avatar
you can use the wastehate on the hx35 to bring down boost. but your going to need headstuds
Old Jun 29, 2011 | 05:39 PM
turbo2332's Avatar
any turbo COULD work just regulate your boost.
Old Jul 2, 2011 | 03:08 AM
stinkyD's Avatar
anyone know were i can get some head studs? for cheap
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
