frontend shimmy when braking
Old Jun 26, 2011 | 09:52 AM
gerald's Avatar
Default frontend shimmy when braking
I have a 2002 3500 silverado going down the road when you step on the brakes the frontend starts to shimmy . I have replaced the upper A arms,idler arm and bracket,front brakes but havent turned the rotors . Evrything seems to have no playbut still shimmys . Any ideas? I am going to pull the rotors back off and have them turned to see if that will help.
Old Jun 26, 2011 | 12:40 PM
BriteWhiteRam's Avatar
the rotors are probably warped, same issue with my truck, you're probably better to replace the rotors and pads with new ones, there are tiny cracks in my rotors and they seem to get worse when they get hot, having them machined probably wont permanently fix the issue
Old Jun 26, 2011 | 12:53 PM
gerald's Avatar
thanks alot we took the rotors off and could see a hotspot on one so will replace all of them
Old Jun 28, 2011 | 12:56 PM
cfarley0210's Avatar
Ya i would say u need some new rotors. They are most likely warped
Old Jun 29, 2011 | 10:46 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Rotors Cheap and easy job
stump
5.9L CR Performance
Jun 11, 2015 09:52 PM
Joel Steven
Nov 16, 2014 05:49 PM
