97 dodge wont move
Old Jun 25, 2011 | 08:05 PM
chevyk1500's Avatar
Default 97 dodge wont move
i need some help a havea 97 dodge 4x4 with auto tran
was just drive ing down road n it stoped now ti wont go fwd or rev messed with t case played with lnkage n tested the ports on trans have 275 psi in rev @ 1500 rpm with 100psi in 1st with 1500 than nothing i have no clue what to do dont hear any non normal sounds can any one help leed m in the right way thanks
Old Jun 25, 2011 | 10:16 PM
rallyit67's Avatar
Input shaft maybe? Not sure about an auto trans but my 5 speed broke and it wouldn't move or make any different noises like you are saying
Old Jun 25, 2011 | 10:39 PM
chevyk1500's Avatar
thats what i think butt dont wan2 get the shaft take in it 2 a shop n just tell m i need a new trans
Old Jun 25, 2011 | 10:52 PM
85_305's Avatar
Being Evaluated
Welcome jake! Glad you made the right choice in joining. Although, poor choice in username.
I have a feeling its the input shaft too. The truck was turned up by the prior owner, its got fuel plate work, a boost elbow, and silencer ring removed. But the trans busted while he was just putting down the road, which I thought was odd. Do you guys eccomend a billet input shaft or will a stocker suffice for his mods?
Old Jun 25, 2011 | 10:57 PM
440ctd's Avatar
better to have it and not use it than need it and not have it
Old Jun 26, 2011 | 01:30 AM
gone ropin's Avatar
i'm running the sunnex one in my tranny, the shaft and front drum assembly are one pice, so far it hasnt broke, i need to up date my sig, but when i dynoed my truck 3 months ago it was at 490 hp with 900 torque, i'm running 370 injectors with a hx 40/35 hybrid turbo, and a custom cam i had ground to my specs, and 17 degrees of timing, and a custom tranny i built myself, with a gorends converter and VB,, good luck
Old Jun 26, 2011 | 05:06 PM
chevyk1500's Avatar
well should i let a trans shop do it or will it be a pain if i buy a rebuild n install my self
Old Jun 26, 2011 | 07:21 PM
85_305's Avatar
Being Evaluated
You would 90% sure not be able to do it yourself, Hoss. Thanks for not including me in the fishing trip!!
Old Jun 26, 2011 | 10:31 PM
newsmoke's Avatar
when my input shaft went it did the exact same thing...
Dec 29, 2014 10:20 AM
Dec 19, 2014 02:30 PM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
