New vp44 and still wont run
Old Jun 24, 2011 | 11:02 PM
Atrainscummins's Avatar
Default New vp44 and still wont run
she died on my way to work 3 months ago and since have had a couple mechanics take a look and do some work. I have a new vp44, injectors, and a tps. We have got it to run since but not good enough to drive and now its not wanting to start at at all... I need some ideas
I dont know the exact fuel preasure from lp but will test that tomorrow.. Looks to be a suficiant amount of diesel, but thats just eye ballin it
Last edited by Atrainscummins; Jun 24, 2011 at 11:02 PM. Reason: Automerged Doublepost
Old Jun 24, 2011 | 11:05 PM
RAW's Avatar
RAW
Transfer pressure? Power to VP44? Codes?
Old Jun 25, 2011 | 12:29 AM
ablackburn's Avatar
I would certainly check fuel pressure. Also since you put in a new pump I would check all the electrical connections. It could have started once by chance on bad connection. Its not likely but these things happens. Sometimes the biggest problems are the simplest mistakes.
Old Jun 25, 2011 | 11:12 AM
ifyoucantdodgeitramit's Avatar
try replacing the lift pump and fuel filter and start the truck by spraying brake cleaner into the turbo
Old Jun 25, 2011 | 12:10 PM
Default Re: New vp44 and still wont run
Don't spray anything any where.
Luke
Old Jun 25, 2011 | 08:24 PM
connermcpherson's Avatar
Unless ur running 14:1 and are spraying ether, NEVER spray anything in you motor.
Old Jun 26, 2011 | 09:27 PM
empty wallet's Avatar
I am having similar issue... have IIS hr vp44 that is brand new, raptor 150. my issue seems to be that im getting fuel at the vp bleeder but not to my engine. have power at vp harness, cleared codes from old vp44 that died and none have returned... seems as though I could be getting air in somehow?
Old Jun 27, 2011 | 06:22 PM
I still havent tested lp pressure, and I understand the importance of that, however I think I am having a separate issue. I have checked all plugs and lines and everything checks out ok. How easy is it to indtall this pump out of time. I help my mechanic set it and it seemed fine though. Thats the 3rd time I pulled it trying to solve this issue.
When trying to start the truck it tries to run but just doesnt crack off like a cummins. The motor shakes and exaust smokes but the motor is super quiet and petal has no responce?
This has gone on way too long and I am short money and hopfully with some wise words of wisdom I wont have to go to dodge
Lp is putting out 12-15 steady. Also bled lines again had tons of fuel to injectors. What to do now?
Last edited by Atrainscummins; Jun 27, 2011 at 06:22 PM. Reason: Automerged Doublepost
Old Jun 27, 2011 | 08:10 PM
well, dont go to dodge. I am new here but I've been running cummins for years. I'm sure everybody here with all our experience will help you out.
as for my 2 cents, have you PHYSICALLY RESET your apps? Just because it is new doesnt mean it is caliberated... and I don't mean unplugging batteries (that resets ecm, not apps). Your apps voltage should read .502 if you probe orange wire w/ blue tracer coming off the plug on the firewall (passenger side)... try that. And don't feel too bad my truck has been out of service for the longest in the 5 years I've owned it, and that is now 2 weeks
CORRECTION, you have a 99, your voltage might be a bit higher... also, are you throwing any codes? that can also be key information.
Old Jun 29, 2011 | 08:24 PM
skyler1101's Avatar
check the lift pump
