shaking at idle
Old Jun 24, 2011 | 01:57 PM
cummins_guy's Avatar
Default shaking at idle
today while I was reworking my cylinder head, I found #5 and #6 exhaust valve only holding 10 Hg, so I reworked the seats and they are back to 25 Hg.
here are some pics of my rebuild
the pictures with the exhaust valve out, that is after I reworked it (on a peterson 25 guide and seat machine)
the picture with the piston, this was the worst of them(just alot of carbon build up)
Attached Thumbnails shaking at idle-bad-vacuum-test-2.jpg   shaking at idle-piston.jpg
Old Jun 24, 2011 | 02:02 PM
here is before and after pics
Old Jun 29, 2011 | 04:19 PM
t-bone117yamaha's Avatar
when you say shaking at idle are you talking about like sitting at a stop light and all of the sudden your truck starts to shake a little? cus i have that problem every now and then some times worse then others
Old Jun 29, 2011 | 05:51 PM
KD93's Avatar
Good work Cummins Guy, very nice!
Old Jun 29, 2011 | 06:57 PM
1arock's Avatar
If the idle rpms drop too far these baby's will shake like a stripper needing to make a rent payment.Rocky
Old Jun 30, 2011 | 02:25 AM
901stgen's Avatar
I have that same weird shake when i come to a stop at a light..... sometimes its worse than others also. Its got me confused.
Old Jun 30, 2011 | 10:54 AM
so is it something that i should look into and maybe turn up the idle a bit? or is it just something that wont really make a difference other then stopping a little bit of shaking every now and then? thanks
Tanner
Old Jun 30, 2011 | 12:50 PM
KD93's Avatar
What's your timing set at? If you increase the timing it will shake the engine a bit more. Although not sporadically... Is your KSB cycling on and off?
Old Jun 30, 2011 | 10:03 PM
Rusty89Cummins's Avatar
mine did the same thing. almost like a nasty lope sometimes. especially after getting into it hard for a long shot. i some things i thought of are maybe timing, possible air in fuel issue, or idle too low. i turned the pump up some more to bring my idle up 100 rpm and it seems to be doing better now. i just havent had time to look into messing with my timing yet since its advance 1/8" to the head.
Old Jun 30, 2011 | 11:22 PM
SNOOT's Avatar
Its probably a injector with a bad pop... Clean and pop test your injectors...
