injetor reducers?
Old Jun 23, 2011 | 04:16 PM
forgasm's Avatar
Default injetor reducers?
i p pumped my gen one and cant find any reducers for the injectors to fit my head. if anyone had any ideas thanks for the help
Old Jun 23, 2011 | 07:28 PM
1arock's Avatar
What year is your engine? What did you use for fuel lines? If you used the lines that came on a p-pump dodge cummins, you will need 2nd gen injectors as the nuts are different sizes for 1st and 2nd gen and also the injectors are set to a different pop pressure. When you go to one of them new fangled late model p- pumps now you gotta buy 2nd gen injection parts.Rocky
Old Jun 23, 2011 | 07:47 PM
forgasm's Avatar
i had to use the lines that came with the pump. the engine is a 90. i got brand new injectors for a p pump engine. the only thing i need is the reducers for the injectors i just dnt know anywhere to get them
Old Jun 23, 2011 | 08:00 PM
KD93's Avatar
Post your question up in the Armory on here. Then the vendors will see it and get back to you.
Old Jun 24, 2011 | 09:25 AM
rlyncoal's Avatar
You can order the 9mm to 7mm reducer from anyone who sells first gen injectors so take your pic between are sponsors. Here is a useful link on cummins evolution. Dodge Ram Diesel Engine Evolution.
