Towing engine temps.?
Old Jun 23, 2011 | 09:47 AM
CUMMINS OR NUTHIN's Avatar
Default Towing engine temps.?
is a sustained 215 degree engine temp. on uphill grades while towing a little on the warm side for my cummins, or do you guys see these temps. on these hot summer days.
Old Jun 23, 2011 | 12:09 PM
MegaMan's Avatar
I've been seeing the same issue. Just had my transmission serviced (auto) & it seems to have dropped a couple degrees. It's time to flush the cooling system too, that'll probably help get a couple more points. Curious to see what others have to say. I don't like getting over 200, that seems to be normal. What's your EGT running?
Old Jun 23, 2011 | 12:35 PM
dangerous1965's Avatar
That's normal and when you start down the hill it will drop back to 200!
Old Jun 23, 2011 | 12:54 PM
im towing about 9000 pounds. egts are at about 1100 to 1150 when engine temps are about 215. I dont like seeing her go over 200 either.
kind of wondering if its fan clutch time, she has 143,000 miles, i dont know how long these fan clutche last.
Last edited by CUMMINS OR NUTHIN; Jun 23, 2011 at 12:54 PM. Reason: Automerged Doublepost
Old Jun 23, 2011 | 12:56 PM
cerberus60's Avatar
Higher engine temp just gets more power out of the fuel charge. As long it is 220 or under its generally not a problem.
If your reading the cluster gauges its probably not accurate anyway, and, depending on where you read the temp in the block it will vary.
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Sep 29, 2014 12:40 PM
