RPM limits
Old Jun 22, 2011 | 11:41 PM
Island Diesel's Avatar
Default RPM limits
I have a truck that had an RPM runaway after a turbo failure. What RPM's are being run on pulling trucks before you see stretched rod bolts, head gasket failures and damaged valve springs? Truck is a 98.5, 24 valve.
Old Jun 23, 2011 | 01:39 AM
banditsdiesel's Avatar
well first off what did you turn it to and what egts did it see and what boost did it hit and for how long
Old Jun 23, 2011 | 08:50 AM
This is a stock truck. The RPM's were caused by fueling off oil from the turbocharger. The truck has no gauges other than stock. The computer snap shot of the over speed shows 4500. I have seen the run away on mechanical engines and usually it destroys at least 1 injector and then the associated cylinder. This engine shows no signs of damage.
Old Jun 23, 2011 | 02:18 PM
clean everything really well then replace the charger. if it comes down to being over cautious pull the injectors to inspect them and check the compression. and if your really wanting to get into it get a bore scope and look inside the motor. i would think your ok with an oil related overspeed because it runs all the cylinders not just one. i turn my vp44 drag truck 4500 every pass down the track.
BlueBell2000
Sep 10, 2015 05:33 PM
InheritedDiesel
Apr 12, 2015 04:35 AM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
dutchsupreme
Dec 18, 2014 01:44 PM
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
