Front U joint Needs replacing
Old Jun 21, 2011 | 12:41 PM
gsancheznm's Avatar
Default Front U joint Needs replacing
04.5 cummins need to change the front ujoint... Do I need to pull the front axle out?? What seals need to be replaced?
Old Jun 21, 2011 | 11:27 PM
Kummins Kid's Avatar
I have the same truck and i replaced the front u-joint about 2 yrs ago. i didnt have to pull the axles or anything and i just replaced the rear seal of the pumkin. hope this helps
Old Jun 22, 2011 | 10:13 AM
steved's Avatar
Which "front" u-joint...the u-joint on the driveshaft, or the steering knuckle u-joint in the axle?
If its the knuckle joint, both the wheel unit-bearing and axle shaft need pulled to replace those joints. If one u-joint is bad, chances are the other is soon to follow. If the axle seal isn't leaking before you pull the axle shaft, chances are (if your are careful) it wouldn't need replaced. I've had mine in/out at least three times, and have no leaks at 255k.
Old Jun 23, 2011 | 12:08 PM
gsancheznm's Avatar
Thanks for the info It was the front driver side steering knuckle...Pulled it out and Replaced it... The wheel hub was really hard to remove. All Back together and runnig good...
shingi
Off Roading
Sep 30, 2015 11:17 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
oznation
May 26, 2015 09:23 AM
Natenelson1
Jan 19, 2015 07:23 PM
