What size is this turbo
Old Jun 21, 2011 | 12:39 PM
skeet615's Avatar
Default What size is this turbo
there is a turbo on an old concrete mixer at work and i was going to see if its worth taking and putting on my truck. How do i figure out what size it is and if it would work? it has a huge induction into it and the exaust out of it is like 4 or 5 in right off the turbo i dont see number but the warning tag says holeset. can any one help me figure out the size of it
Old Jun 21, 2011 | 01:18 PM
RAW's Avatar
RAW
Not too sure the exact size, but it does look suitable for a bottom charger in a comopund set up. It would take A LOT of fuel to spool that up as a single.
Old Jun 21, 2011 | 01:39 PM
skeet615's Avatar
could i use my stock hx35 for a pusher.. and do u think its around a 74mm or something
how much fuel are we talking what else would i need to spool it
Old Jun 23, 2011 | 02:24 PM
young gun's Avatar
i had the turbo on my truck as a bottom charger. it sucked. it can work but the housings need changed. it has a T6 flange and is way to big to run as a single. i wouldnt recommend it. thee turbo model i think is a HT60. i had bought the truck with the set up and found out it was pretty rigged.
Old Jun 23, 2011 | 07:51 PM
keithduke01's Avatar
can you get me the engine serial number off the engine and i might be able to tell for sure what model turbo and maybe some specs on it
Old Jun 24, 2011 | 08:05 PM
skeet615's Avatar
yeah ill try to get it for you ill look tonight if i work if not it will be on monday ...
what would i have to do to my stock charger to use it as a pusher what kinda housing do i need? im just trying to do a cheap twin set up because i can get that turbo for cheap from work.. thanks alot guys
Old Jun 24, 2011 | 08:23 PM
RAW's Avatar
RAW
I am using a stock HX35 as my top charger, and a S400 as my bottom. Spools fast, and produces cold boost.
https://www.dieselbombers.com/5-9l-2...urbos-2-a.html
Old Jun 26, 2011 | 08:16 PM
young gun's Avatar
both turbos need wastegates too reduce drive pressure. and the hx35 isnt made to ush air through it and will cook itself. mine did it!
Old Jun 27, 2011 | 12:53 AM
skeet615's Avatar
On the big holeset it says 24k5 does that mean anything.. And when I do the twin set up can I turn my stock manifold around to get the hX35 up high enough to put the bigger turbo below it
Old Jun 27, 2011 | 07:32 AM
RAW's Avatar
RAW
Not too sure on the 24K5.
When you do COMPOUNDS, yes you can turn the manifold upside down to make room. That's exactly what I did.
