COOLANT?
Old Jun 21, 2011 | 10:59 AM
CUMMINS OR NUTHIN's Avatar
Default COOLANT?
Just changed my water pump, I put prestone 50/50 mix for all makes and models back in the truck, will that coolant work okay in my cummins. Also do i need to put an anti-cavitation additive in with the coolant, and what brands do you reccomend?
Old Jun 21, 2011 | 11:32 PM
Kummins Kid's Avatar
someone once told me to only use the higher quality coolant, not sure what brand but i know its pink in color. they said the coolant for all vehicles can cause problems in the cooling system in diesels but i dont know this for sure.
Old Jun 22, 2011 | 10:08 AM
steved's Avatar
This was asked on another forum recently...the answer is yes, any quality coolant will work in a Cummins, as they are not prone to liner pitting like other diesel engines. The later 3rd gens use the newer HOAT coolant IIRC, but its more of an extended drain coolant.
Old Jun 23, 2011 | 10:36 PM
Bucholz's Avatar
i would suggest using john deere coolguard 2 its the best coolant out there and its designed for diesel. and it has a 6 year life span
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
