ford coolant color?
Old Jun 21, 2011 | 06:27 AM
Little Luke's Avatar
Default ford coolant color?
What collor is my coolant suppost to be? I just installed my filter kit and its green. I had thought I had read it was suppost to be gold.
Old Jun 21, 2011 | 07:13 AM
spelt22000's Avatar
who put the coolant in and when?? To my knowledge green is not good unless there is a green coolant that is compatable which i dont think there is.. someone else will chime in here with the definite answer
Old Jun 21, 2011 | 08:12 AM
I'm not sure. The dealership put my oil cooler and egr cooler on right before I bought the truck, you'd think they would have said something.
I know there is alot of info on one of the threads on here, but in all honesty, I'm working todayfrom 6:30a.m. till 9pm, and dont have time to read them. So I'm gonna need yall to spoon feed me on this one so I can deal with this tonight. Thank you
Old Jun 21, 2011 | 05:57 PM
Mdub707's Avatar
They're bad if they mix. Supposedly you can run the green coolant in a 6.0 (though it's not recommended and it doesn't meet Ford's Specs, but running it for a short time probably wouldn't hurt). The real issue is if you're running gold and accidentally top it off with green and the two get mixed, that's no good.
Personally I'd still do a coolant flush and put the gold back in. Just my 2 cents.
Old Jun 21, 2011 | 11:23 PM
flush is happening this week for certain. I lost alittle coolant when I put the filter on and needed to top it off with somethng, the bottle is still about a 3rd of the way full after its up to temp.
Old Jun 24, 2011 | 03:16 AM
PowerstrokeTech87's Avatar
ITS REALLY bad when you mix green and gold. Doesnt matter how much of it you mix because theres still gold coolant in the block in the heads and in the oil cooler. WHen green and gold mix they make jelly. and plugs ports and cracks heads or blocks or oil coolers egr coolers etc etc.
I dont know how many 6.0s ive warrantied because of customer ignorance... or pure stupidity.
Old Jul 6, 2011 | 11:07 AM
windmankarr's Avatar
what are the best three coolants for the 6.0's
Old Jul 6, 2011 | 12:16 PM
Mdub707's Avatar
What's the best three sandwiches in the world?
I don't think you're going to get one answer for that.
A lot of guys run the CAT ELC coolant, it's red in color. I will say it does NOT meet Ford's spec for coolant though.
I've run Ford's gold stuff since the beginning, I'm at 87k miles, have the original oil cooler, just recently deleted EGR cooler, running a dieselsite coolant filter kit since about 65k miles, and my EGT and ECT delta runs around 3-7 degrees difference. I will continue to run the gold stuff for now.
Old Jul 7, 2011 | 03:01 PM
DieselPower84's Avatar
Can we use that prestone any color mix for these?
Old Jul 7, 2011 | 03:22 PM
Mdub707's Avatar
Whatever you use, DO NOT MIX different coolants, AT ALL. Do a FULL flush before putting a different coolant in.
That Ford Gold stuff is pretty special from what I've seen, I wouldn't mix anything with it.
