12 valve mods
Old Jun 18, 2011 | 06:16 PM
95 cummins ole smokey's Avatar
Default 12 valve mods
i have a 95 cummins 5spd, has #0 fuel plate full forward, gutted afc, 140hp ddp injectors, dozer air filter, 4" turbo back to 6" stacks.
the stock turbo went out from pushing 42lbs boost in the stock hx35...
i want to put lazer cut delivery valves in, an a air dog II, 4000 gsk, a dual disk clutch, an wanting a good turbo that can run good with all that. maybe even twins..
need help on finding a nice setup..??? ideas??
Old Jun 18, 2011 | 11:40 PM
12vcummins96's Avatar
yeah a 64/71 14cm would be a great charger then if you wanted twins throw an s480 under it and it would be dynomite
also why lazer cuts i would go with smokem specials fuel just as hard as lazer cuts but smoke less than 191s
Old Jun 19, 2011 | 06:54 AM
6btsmoker's Avatar
Twins spool up fast and keep temps down.
I have the BD towing twins and they work good.
Great spool up,boost,and low egt.
Old Jul 30, 2011 | 09:06 AM
i have an hx40, would that be a good one to run?
Old Aug 2, 2011 | 02:55 AM
BRE's Avatar
BRE
Not really...
12vcummins96 has pointed you in the right directions on everything as of this point.
Old Aug 2, 2011 | 09:40 AM
South Tx Coal Roller's Avatar
Originally Posted by BRE
Not really...
x2
RA113024
Mar 13, 2016 07:42 PM
12 valve 97
5.9L 12V Performance
21
Jan 27, 2016 04:59 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
