Foamy/Bubbly Oil?
Old Jun 17, 2011 | 03:49 PM
901stgen's Avatar
Default Foamy/Bubbly Oil?
I just recently replace my lift pump and I was wondering if foamy/ bubbly oil was a sign of fuel in the crackcase?
Old Jun 17, 2011 | 04:02 PM
1arock's Avatar
Looks like a hot oil drain to me(the best way to do it imo) does it smell like diesel, is it a thin as water, was it way over full? If you didn't notice any of those things that don't look bad to me.Rocky
Old Jun 17, 2011 | 04:06 PM
901stgen's Avatar
No it wasn't hot when I changed it. It does feel a little thinner and cant really make out a distinct smell of diesel. Probably cause my allergies have me all stuffed up.....
Old Jun 17, 2011 | 05:05 PM
RSWORDS's Avatar
Picture almost makes it look chunky... When you change it last?
I would keep on eye on the level. If it does not rise your fine.
Old Jun 17, 2011 | 05:08 PM
KD93's Avatar
Oil like that is usually caused by aeration, (air in the oil) from the level being too high. The crank journals whip the oil and aerate it. Not a good thing as air is compressible. It'll cause voids in the oil which will means less lubrication for bearings etc. resulting in faster wear.
Old Jun 17, 2011 | 05:42 PM
901stgen's Avatar
I changed it probably not even a thousand miles ago after I put a new head gasket on it. Its not chunky the air bubbles just make it look that way. The reason i changed it again was because i thought there might be fuel in my oil because when i pulled my dipstick there were bubbles on it.
I never over fill it. I make sure of that.
Old Jun 17, 2011 | 09:47 PM
1arock's Avatar
You say you recently put a head gasket on it. Stick a screwdriver in the drained oil and hold a match or lighter under the oil on the screwdriver (or dipstick if you have not changed your oil for a while) if it sizzles pops and sputters like spit on a hot iron it has water in it, if it just smokes and burns you are okay. Just a few drops of water in the oil will make if act up like a house cat with it's tail caught in a screen door. You very well could have contaminated the oil when you changed the headgasket. It's really hard not to. I'd run it a few miles and check it again see if it don't clear up. Just my opinion because as I just learned in another thread I'm just a nube.Rocky
Old Jun 18, 2011 | 08:02 AM
KD93's Avatar
If there was diesel in the oil, the oil would 'separate' on the dipstick. Meaning there would only be 'puddles' of oil as opposed to a complete covering.
Glad you don't overfill it.
Old Jun 18, 2011 | 08:28 AM
jwirth's Avatar
The best way to find out if you have a problem is just go get an oil analysis done.
Old Jun 18, 2011 | 01:47 PM
901stgen's Avatar
So i tried this last night and theres definitely no water in the oil.
