black smoke edge juice or quad
Old Jun 17, 2011 | 01:12 AM
skyler1101's Avatar
Default black smoke edge juice or quad
hey guys i can roll alot of coal right now with my edge juice with the hot unlock but i have been lookin at the new quadzilla adr with i quad and it looks pretty sweet i would like to either change to this or stack my edge with a smarty any comments or suggestions??? i just really wanna roll some coal and make a lot more horse
Old Jun 17, 2011 | 02:20 PM
ironhead79's Avatar
Do you have the correct pump wire tapped? You should be able to put out a fair amount of smoke with 150s, also have you adjusted the sub levels on the comp? If not push & hold the power button for a few seconds then release, once it flashes you can adjust. just some ideas for you !
Old Jun 17, 2011 | 02:38 PM
01quadcab's Avatar
waste of money to go to the quad it's not going to give much if any more hp. the smarty only gives some bottom end but you loose hp. add a good turbo and you will be a lot happier with the hp
Old Jun 17, 2011 | 11:30 PM
skyler1101's Avatar
hmm ok guys and yeah i have the low end responsiveness turned all the way up on the edge and i do have the right wire i mean by all means it does roll quite a bit of coal but im still just lookin for a little more and with a better bigger turbo wont i get less smoke i no i will get more horse... anyhow though if i stack the smarty with my edge how do i lose hp?? thanks guys!!!!!
Old Jun 18, 2011 | 03:31 AM
banditsdiesel's Avatar
you dont loose in a stack you just dont gain advertised amounts. the quad adr gains the same if not a few more than the ejwa-smarty stack for a lot less money.
Old Jun 18, 2011 | 11:50 PM
01quadcab's Avatar
with the smarty you loose hp on the top end put the truck on the dyno it has been proven.
Old Jun 20, 2011 | 02:39 AM
really???? because my 99 picked up 32.8 whp more with the smarty stacked on an ejwa. it did loose in the top rpm range but peak was higher. but know with my adr 4K its blows that stack out of the water.
Old Jun 20, 2011 | 06:17 AM
Default Re: black smoke edge juice or quad
No one looks at peak HP numbers.
Luke
Old Jun 20, 2011 | 09:53 AM
01quadcab's Avatar
I lost hp and track times with it. but I was running a drag comp maybe the juice is different. I tried the quad and sold it because it too slowed me down.
Old Jun 20, 2011 | 02:55 PM
Luke
then what are you looking at
i have heard mixed emotions on the quads i have the adr 4k on mine but have really had a lot of time to test it on the track and i dont run it on the street. dont need it.
Last edited by banditsdiesel; Jun 20, 2011 at 02:55 PM. Reason: Automerged Doublepost
