cummins died and wont start please help
Old Jun 16, 2011 | 09:33 AM
crazyeyes's Avatar
Default cummins died and wont start please help
hey bombers Iam brand new to this site and need help my truck died everything was great it runs fine pulled down the driveway and it shut off just like you turned the key off now it turns over but wont fire at all it is a 03 5.9 cumins and has a programmer on it never had problem before and don't no much about diesels can anyone give me a few things to check or a place to start looking at least it seems like a easy fix but like i say my diesel knowledge is very limited thank you. crazyeyes
Old Jun 16, 2011 | 09:38 AM
kingbrad89's Avatar
Sounds to me like it's a fuel pump problem
Old Jun 16, 2011 | 09:57 AM
crazyeyes's Avatar
do you check that the same way as a gas just listen under the tank
Old Jun 16, 2011 | 11:32 AM
dangerous1965's Avatar
First clean your battery connections! Remove them all wait a few minutes and clean them ALL! Cummins are great for that!
Old Jun 16, 2011 | 11:59 AM
crazyeyes's Avatar
ok i will try that but would a corroded battery post make it die like that is there a connection for the fuel pump on there or something
Old Jun 16, 2011 | 12:02 PM
AHolt's Avatar
I would check for codes first.
Old Jun 16, 2011 | 12:12 PM
crazyeyes's Avatar
my brother did but he was pretty vague on what it said he said there was 5 codes but 4 of them had to do with the programer like turbo related codes and the last one was something like low voltage to the ecm or interrupted current or something like that I will have to check with him to get the exact wording. is that what happens if the battery terminals are dirty?
Old Jun 16, 2011 | 01:26 PM
YUP!!
Old Jun 17, 2011 | 04:28 AM
dieseldean's Avatar
is it getting fuel to the cp3? if not, it's likely the in-tank pump. I don't think the 03 will throw a code for that- the computer is not as savvy as it is on the later models. Cycle your ignition 3 times (without turning all the way to "start") and on the third turn, leave it in the "on" position. That will display any new codes in the odometer window. The connections for mine are at the pump, so you'll need to drop the tank, or lift the bed to access it. good luck!
Old Jun 18, 2011 | 01:13 AM
Fireman_Dave's Avatar
Lift pump?
