LEAF SPRING BUSHINGS ?
Old Jun 15, 2011 | 11:39 PM
sweetv8s10's Avatar
Default LEAF SPRING BUSHINGS ?
I was wondering if anyone knows the best way to take out the bushings in the leaf springs I ordered mine today so I have not took it apart yet but I was told they can be a pain in the a to change just wanting some ideas?
Old Jun 16, 2011 | 09:18 AM
tower_ofpower's Avatar
Could heat the spring slightly to open the eye up. Or use a wedge and drive it between the leaf and the eye to relieve some pressure on the bushings collar. It's going to take some solid hits, I removed the ones from my skyjacker springs and replaced them with urethane bushings. They came out hard enough being new so... Good luck
Old Jun 16, 2011 | 08:30 PM
RSWORDS's Avatar
BFH....
Old Jun 16, 2011 | 08:48 PM
Rusty89Cummins's Avatar
find someone with a press and youll be all set. well thats if ur taking ur hole leaf spring pack.
Longshot's Avatar
you can burn them out with a torch. but watch out the steel sleeve will shoot out when it gets hot enough
Old Jun 19, 2011 | 09:05 AM
dzlinmyblud's Avatar
ya burn them out and use a air hammer and just push them threw, the i made up a tool big/ long threaded rod welded a nut on one end with big washers and press the new bushing in with that. works well if you have a half inch impact gun.
Old Jun 19, 2011 | 01:28 PM
1stGen1990's Avatar
i did my front ones and they are polyutherane i believe with a steel sleeve that the bolt goes through. Mine were pretty stuck in there i had to drill outt the steel sleeve and work around the bushing and between the spring with a screwdriver to get it loose. It was a pain in the @$$
Old Jun 19, 2011 | 02:05 PM
forgasm's Avatar
air hammer works good, just make sure its a good one and it will knock em right out no problem
Old Jun 24, 2011 | 01:49 AM
mnwild_05's Avatar
a buddy of mine says a ball joint press works good i haven't tried myself though.
Old Jun 24, 2011 | 08:26 AM
RSWORDS's Avatar
Get em out yet?
