Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
LLY problems?
Old Jun 15, 2011 | 10:01 AM
KuNtRy BoY's Avatar
Default LLY problems?
Just wondering what are some things to look for, and what are the the major problems that I should be worried about? Ive owned 2 LB7 but I found a really nice 04.5 Ive been eye balling. Thanks.....
Also what, if any is the power difference between the 2
Last edited by KuNtRy BoY; Jun 15, 2011 at 10:01 AM. Reason: Automerged Doublepost
Old Jun 15, 2011 | 07:46 PM
BriteWhiteRam's Avatar
the LLY suffers from induction overheat issues, especially while towing or being worked hard, you can do some fairly cheap mods(LBZ turbo mouth piece) to help alleviate the problem but not entirely fix it
the LB7 makes 300hp/520tq, the LLY makes 310hp/605tq
Old Jun 16, 2011 | 11:06 AM
KuNtRy BoY's Avatar
Thanks.
Old Jun 21, 2011 | 07:42 PM
cbsmoraine's Avatar
like white mentioned above there is the induction problem, cheap fix is a LBZ or KODIAK turbo mouth piece (i prefer the KODIAK), also the PCV need to be re-routed out of the intake and off to the side of the engine to a catch can, the EGR system need to have blockers installed. Another cheap fix is to cut the cat and the muffler out and install flex pipe or standard 3.5 inch piping, it will helpwith your EGT's and and your turbo will spool slightly faster. may even help out with horse power by 5 or 10 and mpg by 1 or so. I got a quote at a local muffler shop here in abilene tx for $120. you can also (just for looks) relocate the antenna from where it is, to under the hood (takes like 10 minutes and all you need is a cresent wrench, 7mm socket with 6 inch extention, and a handfull of zip ties.
Bloom12valve
Oct 9, 2015 03:40 PM
Brody Olson
Chevy/GMC Duramax 06-07 LBZ
Sep 12, 2015 11:01 PM
Zachbishop
Feb 10, 2015 10:23 AM
Tucker126
Jan 2, 2015 08:09 AM
duramaxtuner
04.5-05 LLY Performance
Dec 10, 2014 01:56 PM
