94 12 valve in 99 24 valve motor mounts
Old Jun 14, 2011 | 12:07 PM
millwright350's Avatar
Default 94 12 valve in 99 24 valve motor mounts
Hello every body im getting parts together to do a 12 valve swap in my 2002 F-150 i was dreading boxing in the frame and suporting it for the new motor and life as a 3/4 ton then a buddy of mine got a 99 24v truck for the motor to put in his f-350 and i got the frame for a song im planing on just putting my cab on the dodge frame just wondering if the 94 12v will fit in the 24v motor mounts i know the bolcks are verry similar im just not positive on the motor mounts any help would be greatly appreciated
I am also going to make the 2wd frame into 4wd is it possible to just buy a lift kit for a 4wd and put it on the frame i know some things will be difrent but will the spring cups be in the same places i have a dana 44 and 80 out of an older dodge truck not shure of the year
thank you all
Old Jun 15, 2011 | 12:41 AM
banditsdiesel's Avatar
as fars as the frame placement it should be exactly the same even the 5.9 gasser is located in the same place on the frame....
Old Jun 15, 2011 | 12:06 PM
Thanks i figured the placement would be the same but im more concerned with the the mounts them selfs if the 12valve block will right in the 24valve mounts
Old Jun 15, 2011 | 08:31 PM
thebullet83's Avatar
i think the blocks are pretty much exactly the same. the front case and the head were the big changes.
Old Jun 18, 2011 | 03:26 AM
thats what i was saying they are all i the same place mounts on the motor and the frame. setting one in it should fall right into place.
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
