Modified Fuel Module with Drawstraw
Old Jun 14, 2011 | 11:19 AM
oudive's Avatar
Default Modified Fuel Module with Drawstraw
Sup,
So my fuel gauge has started fail on me and since I have had some issues with the 1/4 tank and the drawstraw, I got to thinking and searching. I originally had the drawstraw that came with my AD150 installed, but I cut the straw too short and had 1/4 issues. So in 2009 I ordered another drawstraw to go into my OEM fuel canister. Followed the directions and measured twice before cutting. Still having issues but only as I was low on fuel and hitting the brakes. My AD return is routed into my filler neck, so I called Vulcan and they gave me some good advice. Found a great deal on a new Airtex fuel module with the intank pump. So I purchased the DS V and ended up spending less this route than on the modified liberty.
Here are some pictures incase someone may have thought about going this route and doing the bombing themselves. The whole think can be taken apart as you can see from the pictures. You will need a deep 15/16 socket to tighten the bulkhead fitting. Also this will route my AD return to the canister along with the normal return from the engine. So now that it is done, it will be put into action within the week.
oudive
Old Jun 18, 2011 | 08:02 PM
oudive's Avatar
Follow up.....
I got it installed and all with no leaks. Prior I had like 18 psi at idle, now I have 21 at idle. So I knew something was not right before, but it is all good now. I am really digging the DS V.
oudive
Old Jun 19, 2011 | 09:45 AM
turbo20psi's Avatar
O good you can come over and do mine nexted..
Old Jun 19, 2011 | 01:39 PM
oudive's Avatar
I can handle working for beer
Old Jan 20, 2012 | 07:37 PM
cummins23's Avatar
whats the difrence between the airtex and the vulcan
Old Feb 17, 2012 | 06:05 PM
oudive's Avatar
To be honest, not sure the difference.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
