throttle stuck wide open
Old Jun 13, 2011 | 08:18 PM
Chevy355mark's Avatar
Default throttle stuck wide open
The other day i was out 4 wheelin in the dodge, the truck was getting beat on harder then iv ever beat on any truck really, seeing alot of wot time, bouncing around over whoops in 3rd gear. on the way back in the truck just started to run away so i pushed the clutch and killed it, and towed it home. the throttle is stock at just short of wide open, you can move it little but it wont come back down to idle, wont come any lower then maybe 1/16" from full. the cable is slack, none of the return springs ae broken. the pump is just pretty much jammed, either that or im thinking some linkages got muddy and jamed up. what do you guys think?
also, i overheated the truck at the same time this happened, could this have something to do with it? didnt really overheat it that bad, mostly water and the radiator leeks a bit so its not holding pressure, under these conditions it boils out at only like 210 degrees, so its not like i severely overheated it. other then that nothing else is really broken, i can not believe the kind of abuse these trucks will take. hoping ill have an easy fix on my hands, if not easy at least closer to free.
o and some aditional information, i have no fuel plate, afr maxed out and he governor springs are stock but turned in 4 clicks each.
Old Jun 14, 2011 | 01:00 AM
BRE's Avatar
BRE
Rack is hung... Governor spring mishap... Who knows
Old Jun 14, 2011 | 08:02 AM
yea iv read up a little bit on the stuck rack... looks like im just gonna take the afc off and get it to come free and run a ton of 2 stroke oil through it. iv been really slacking on putting 2 stroke oil in the fuel and i have to think that this is how im paying for it... especially on a hot day of beating on the truck with no fuel plate i really should have added some lubricant for the pump, who knows how reliable the pump will be in the future now.
Old Jun 14, 2011 | 11:08 AM
94 12valve's Avatar
have you checked your fuel pressure? sounds like you hung a plunger prob one twords the front of the pump
Old Jun 14, 2011 | 01:11 PM
no i have not. iv got a guage but do these trucks have a regular test port or am i going to need something special to check the pressure?
Old Jun 14, 2011 | 02:22 PM
94 12valve's Avatar
your going to have to rig something up, sounds like yours is low and the lack of fuel could have seized the pump
Old Jun 14, 2011 | 04:21 PM
well should i just change the lift pump? is the pump going to be done for now that it seized up?
Old Jun 14, 2011 | 06:39 PM
94 12valve's Avatar
The pump shop will make that call, first before you go buying things make sure its hung. if it is look into a better or new lift pump
Old Jun 14, 2011 | 08:10 PM
nothings going to any shop... i am the shop. if it needs a pump ill buy a new one from a salvage yard from a later model with a higher rating.
Old Jun 15, 2011 | 08:54 PM
94 12valve's Avatar
why would you do that? If it were me I would just send her to the shop and let them work there magic
