hx 35 swap help!
Old Jun 9, 2011 | 02:26 PM
cam899's Avatar
Default hx 35 swap help!
i need to know i have a 2001 24 valve with the stock hy35 and i want to know if an hx35 off of a 97 12 valve will mount on without any new parts or not please help
Old Jun 9, 2011 | 02:33 PM
RAW's Avatar
RAW
I put an HX35W on my 01 auto, only issue is mounting. Some studs and bolts are in different locations. Bolt hole pattern is the same though.
Old Jun 9, 2011 | 02:36 PM
cam899's Avatar
so it will mount up then for the most part u will just have to move some bolts around or what im going to do it tonight or atleast try
Old Jun 9, 2011 | 08:28 PM
turbostang7's Avatar
yep just have to move some of the studs around and it will bolt up no problem
Old Jun 11, 2011 | 07:58 AM
connermcpherson's Avatar
Or pull the studs out and put in some grade 8
Old Jun 12, 2011 | 12:51 PM
crazycooter's Avatar
make sure you get a divided turbine housing gasket, not the one for the undivided hy35 housing you will notice a spool difference between the two. Just a couple of bucks for them anyway
STDiesel59
Jul 11, 2015 10:09 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
F250MACH
Apr 26, 2015 05:19 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Jgloveracob
Nov 16, 2014 07:27 AM
