cheap mods
Old Jun 9, 2011 | 04:24 AM
powderchoke killer's Avatar
Default cheap mods
i need to know if there is anything that i can do to give me more power at a reasonable price like 200.00 or less
Old Jun 9, 2011 | 07:45 AM
KillStroker's Avatar
Check out the Armory in the forsale section. There might be a few things you could scrap up for a decent price. Like a used CAI. maybe a puck? depending on how u use your truck maybe a set of gears??? Look for a used set of RV275's
Old Jun 10, 2011 | 12:21 AM
thanks killstroker i was also wondering if i could just tweak anything on the truck as it is to give it a coupple of more horses ( i am planning to remove the silencer ring tomorrow just to hear it more and i don't think that it will add any power to it)
Old Jun 10, 2011 | 06:46 AM
Your right removing the ring will not add any. You can always just perform some standard maintenance to your truck like checking your APPS if its out of whack it can not run at top potential. For it to be out is pretty common as well.
Old Jun 10, 2011 | 07:10 AM
RAW's Avatar
RAW
If your handy with a jigsaw, you could cut out your muffler and replace it with a piece of pipe and torque tight clamps. It will flow a little better, downside is it will be way louder and you'll likely have cab drone.
Personally, I would invest that $200 on a fuel pressure gauge. Keeping an eye on fuel pressure can save you a $1000+ injection pump.
Old Jun 10, 2011 | 02:06 PM
about the exhaust i have a 5in turbo back with a straight through muffler that does well b4 i put that on it it had a 3in straight pipe i also have a edge ez module on it
and what is apps i have no idea what that is
Old Jun 10, 2011 | 02:46 PM
A accelerator
P pedal
P position
S sensor
If you look in the DODGE TECH articles you will see a "How to" to adjust this sensor you will need a multimeter.
Old Jun 10, 2011 | 10:40 PM
thanks btw how can i get more airflow to the engine ( already swisscheesed the air box )
and checked all the pressurised airlines from the turbo and it still blows smoke when the chip is turned all the way up and edge says that it isn't supposed to
Old Jun 11, 2011 | 08:02 AM
connermcpherson's Avatar
If it were me, starting from scratch, invest that money in a nice set of gauges. I know u want more airflow and more power on the cheap but in all reality, getting power isnt cheap... its expensive. But in order for you not to drop $1k on a VP, get a fuel pressure gauge. And back that up with a Trans and a pyro. Best advice anyone could tell you..... my .02
Old Jun 11, 2011 | 09:19 AM
BACONBITSFORU's Avatar
Default cheap mods
Fuel, tranny, pyro are a must! Also for more air look for a stage 2 Cole air intake also a ats or afe bladerunner intake horn
