Head Gaskets
Old Jun 8, 2011 | 10:22 PM
bud0994's Avatar
Default Head Gaskets
i am getting ready to do my head gaskets on my 05 F350. i am going to take the heads in to get decked i have ARP studs but i am not sure what type of gasket i should use or a good place to buy one? also while i am in there i am thinking on doing the egr delete is there anything else that i should do while the cab is off and it is easy to get to the whole motor? Thanks
Old Jun 9, 2011 | 07:15 AM
bismic1's Avatar
IMO the OEM head gaskets are best. You can get them for $135 each from TousleyFordParts. Just as an FYI, they come w/ bolts, just discard them. If you want the OEM head gasket by itself, BulletProofDiesel sells them without the bolts.
I believe the part # is 4C3Z-6051-EB. Call them and verify (due to changes in heads in the 05 - 06 time frame).
Tousley Ford
Old Jun 9, 2011 | 09:51 AM
bud0994's Avatar
will there be any problems if i use heads of of a 07 and where are the dowels so i can make sure i get the right gasket
Old Jun 9, 2011 | 01:31 PM
bismic1's Avatar
You can use the 07 heads. You just need the conversion kit for the alignment dowels since the 07's use 20mm dowels and the 05's use the 18mm. Call Tousley - they can get you what you need for a reasonable price. For that matter so can BulletProofDiesel.
Old Jun 13, 2011 | 01:09 PM
bud0994's Avatar
ok thanks ill give them a call
Old Jun 13, 2011 | 05:06 PM
Mdub707's Avatar
Agreed, stick with OEM gaskets.
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Vmason
Jan 21, 2015 11:33 PM
Adam65
Jan 9, 2015 11:50 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
