Idle issues/ Oil pressure
Cant seem to find the Idle Screw on my Truck. Also when i come to a stop my "CHECK GUAGES" light comes on and my oil pressure drops to 0! Im guessing it has to do with my idle being to LOW maybe? its idling about 600 rpm maybe a little less. Just want to know if the truck idling to low may cause the "check Gauges" light to come on?
Here's a link for changing your idle speed. Hopefully it will help.
Ram Diesel Problems
As far as the oil pressure deal, it sounds like your oil pressure sensor is going bad. It's a known issue on these trucks.
Ram Diesel Problems
I'm not trying to be a smart a$$ but you do have enough oil in the motor right?
New 98 12V Cummins Oil Pressure Switch ... $35.... awesome
CUMMINS OIL PRESSURE SENSOR ('94-'98, 12V)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
