How good is the Edge Comp
Old Jun 7, 2011 | 07:43 PM
Cummins Smoke 24v's Avatar
Default How good is the Edge Comp
I just bought me a edge comp box today it should be in tomorrow how good is this thing and should I stack it with my superchips?? And how much do you think it will smoke with my mods I have... superchips flashpaq,BD 150 horse injectors,airdog fuel system,AFE stage 2 intake,4in straight pipe to 6in tip
Old Jun 7, 2011 | 07:56 PM
RAW's Avatar
RAW
I'd take the Superchip out, and run the Comp alone. It's a deadly fueling box! Is it the Drag Comp, meaning unlocked? If you have the Comp on 5x5, it will roll a disgusting amount of coal off the line. Watch the EGTs!!
Old Jun 7, 2011 | 09:43 PM
1st_gen_puller's Avatar
be better off selling the superchip and then u basically have an edge comp for say 500 or so... it will do everything you can ever ask... in my opinion...
Old Jun 7, 2011 | 10:56 PM
01quadcab's Avatar
edge comp is hands down the best for the 24v very reliable.
Old Jun 8, 2011 | 09:14 AM
So get rid of the superchips its not worth stacking? Cause the edge will make more power.? Will it also smoke more with the 150's than it did with the superchips? oh and how easy is it to install??
Old Jun 8, 2011 | 09:40 AM
01quadcab's Avatar
superchip is a waste of time it only adds a little. the comp box will add up to 120hp and with some 150's and a stock charger it should smoke pretty good but your egt's will be pretty hot so you better have a good set of gauges and hopefully you have a fuel pressure gauge or you will be needing an injection pump soon. But keep the smoking people out to a minimum.
Old Jun 8, 2011 | 10:22 AM
wyodiesel92's Avatar
Not to jack your thread but what's the real difference between the comp and juice with attitude, besides the fact the juice allows you to monitor engine data and comes with gauges?
Old Jun 8, 2011 | 11:06 AM
RAW's Avatar
RAW
The comp is a fuel box only, very simple. 3 buttons, 8 wires, one box. The EjWA has the monitor with all of its abilities, including monitoring, alerts, and backdowns. Comp doesn't back down at all, its all POWER!
Old Jun 8, 2011 | 01:34 PM
01quadcab's Avatar
the back downs are killer when you forget to turn them off and are blasting down the track and it defuels at the 1/8th. did that twice and then it was gone. the comp I think fuels harder than the juice.
Old Jun 8, 2011 | 06:44 PM
WOW!! just installed the comp and DANG!! I couldent get it to smoke with just the comp and the injectors it felt like i had a dead pedel.. but now i stacked it with the superchips and SOB it smokes so crazy it is not even funny ... And What is good temp for trans. mine is at 180.. Oh and can I put a Juice monitor on this so I can see me EGT's and Fuel pressuer? I know for a fact the EGT's are over 2000*..... I think its time for a new turbo this stock HX-35 is not cutting it.. Maybe Twins?? or a nice 66mm?? I think I have enough fuel
