Fuel leak..
Old Jun 7, 2011 | 12:28 AM
BACONBITSFORU's Avatar
Default Fuel leak..
All right guys, I fixed my gasket leak this weekend (tappet covet) and no more leaks... 2 days later thro I now have a fuel leak and it's dripping from the bottom of the tranny. Any ideas where is might be comeing from? Also have a code of a bad tps but found out if you ever unhook one you have to real cal it so I fixed that problem... Thanks for and advise also it's stock everything!
Old Jun 7, 2011 | 07:54 AM
RAW's Avatar
RAW
There is a banjo fitting on the back of the head for return fuel from th injectors. It runs to a Tee fitting for pump return, and to tank. I checked mine last night, and found the one into the back of the head to be a little loose. An articulated arm, foul language, and a 11/16" wrench will get the banjo on the back of the head, 9/16" for the fitting on the Tee.
Old Jun 7, 2011 | 09:27 AM
connermcpherson's Avatar
^^^^^ this. if you got fuel running down the trans, its probably the head banjo fitting. 12x1.5 is the fitting size i took mine out and put a steel braided line in with -an fittings to stop the leaking forever
Old Jun 7, 2011 | 09:47 AM
Default Fuel leak..
Cool I'll have to check that out later this week till then I got a gallon jug I put under there when I park to see how much is leaking and to put it back in the tank
Old Jun 7, 2011 | 01:52 PM
RAW's Avatar
RAW
Does it start hard after sitting? A common complaint of these fitting loose is hard starts after being parked up hill.
Old Jun 7, 2011 | 02:15 PM
Default Fuel leak..
Na it starts fine the biggest this is it will not leak when the key is on and motor is not running... But when the motor is running or just after being shutdown it will leak some
Dale9411
Dec 4, 2022 06:51 PM
Dbleo351
Nov 20, 2016 09:34 AM
moneypitk5
Feb 12, 2015 11:01 AM
4x4kingx889
Jan 25, 2015 02:02 PM
Dec 5, 2014 08:30 AM
