A/C Issues
Old Jun 5, 2011 | 11:37 PM
derekk872003's Avatar
Default A/C Issues
My 2001 is having some issues with the a/c ductwork. The fan blows very little air anytime but with the fan turned off at highway speeds theres a fair amount of air being pushed through the vents. From what i can feel with the fan motor out of the way the coil is plugged up with greasy nasty stuff so im sure i need to pull the dash and clean it out. Im looking for some insight on why im getting more air moving without the fan on??? Never had to work on the ductwork before any ideas or tips would be appreciated.
Old Jun 6, 2011 | 09:24 AM
snm76's Avatar
more air at highway speeds could be the fresh air damper is open and the pressure differential is pushing air through the coil into the truck. If you can see the dirty coil, there is a coil cleaner that will eat through that grime and grease you can spray it on the inlet side, wait and rinse. Save you from having to remove that coil which is a pain. hope this helps
Old Jun 7, 2011 | 05:20 PM
thanks for the reply, looked at it a little more, i havent had much time lately. Found a temperature control motor there under the dash that isnt moving with the switch either. any idea if that can be changed without pullin the dash to?
dwmeehan
Jan 29, 2025 12:13 PM
Ric Stokes
Aug 31, 2015 06:58 AM
Maclain Marsh
Jul 13, 2015 06:23 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
