93 3500 with steering problems
Old Jun 4, 2011 | 08:08 PM
mrron90's Avatar
Default 93 3500 with steering problems
have 1 ton reg cab work truck its 4x4 when you hit a pot hole the wheel will shake out of your hand they changed front tires steering box and steering coupler still the same thing not sure what to look at next its a oilfield truck with 17000 hours but only 43000 miles thanks ron
Old Jun 5, 2011 | 07:07 AM
Longshot's Avatar
Might want to try a steering stabilizer
Old Jun 5, 2011 | 10:44 AM
tower_ofpower's Avatar
What about slop in the drag link? I'd make sure all the joints are tight, including the knuckles. With the truck running in park crawl in the fender well and turn the steering shaft back and fowarth while watching for slop in everything.
Old Jun 9, 2011 | 08:48 PM
jwirth's Avatar
All so check front axle leaf spring bushings all 6. Mine were worn out causing the same thing.
Antwhite19
Aug 23, 2015 06:07 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
TKulak
Mar 26, 2015 10:27 PM
sweetv8s10
Oct 7, 2014 09:47 PM
