Loping and worse milage
Old Jun 1, 2011 | 02:43 PM
smokedout's Avatar
Default Loping and worse milage
My truck sounds like theres a cam in it and my milage sucks. Could this have anything to do with my injectors?
and hangs forever when i rev it up
Old Jun 1, 2011 | 04:55 PM
dangerous1965's Avatar
Hanging is normal the lope is not! How many miles on the injectors? Only way to tell is pull them and send them out for testing! Does it do this when cold or always?
Old Jun 1, 2011 | 07:10 PM
smokedout's Avatar
155,000 on the injectors and it does it always
Old Jun 1, 2011 | 08:32 PM
banditsdiesel's Avatar
sounds like you got an injector sticking and getting ready to take a crap. most likely 5 or 6. thats usually the ones that go out the most. you can have some one with a good scanner read the injector pulse width and tell you which one is bad. or out od sync with the others
Old Jun 2, 2011 | 10:34 AM
Boiler01's Avatar
Your injectors may not be in the best shape, but that's probably not the problem or at least your only problem. I would first look at the fuel rail pressure relief valve.
Old Jun 6, 2011 | 09:45 PM
smokedout's Avatar
wheres that at?
Old Jun 6, 2011 | 11:08 PM
Boiler01's Avatar
The fuel rail is between the engine and the fuel filter. The PRV is on top of the fuel rail the second fitting from the front. Loosen the return line on top and then unscrew the PRV, make sure to crack the line first b/c the fuel is under high pressure.
Old Jun 10, 2011 | 10:45 PM
dalton06's Avatar
How would u know if the prv is bad? Does it crack or look bad?
