Quadzilla adrenaline issue
Old May 31, 2011 | 09:00 PM
Razram55's Avatar
Default Quadzilla adrenaline issue
Up to level 5 with my quadzilla i have smooth acceleration and power but when i go up to level 6 and higher the engine will cut out at higher rpms, almost like it is starving for fuel. Also there is no real difference between level 5 and 10, it almost feels faster at level 5. My thoughts is maybe my stock injectors dont flow enough fuel for the higher level tunes. Any ideas? my truck is basically stock, 5 speed, cold air intake, 4" downpipe, and the quadzilla adrenaline with pulse.
Old May 31, 2011 | 09:36 PM
turbostang7's Avatar
no lift pump! you are starving it for fuel! need a lift pump and a fuel pressure gage asap. stock injectors will be fine on all levels
Old May 31, 2011 | 09:39 PM
Razram55's Avatar
sorry failed to mention i have a ppe lift pump and the bd low fuel pressure light, light never comes on with this lift pump.
Old May 31, 2011 | 10:09 PM
Default Re: Quadzilla adrenaline issue
I would try loading a different tune on t and see if it does the same, which one are you running now?
Sent from my DROIDX
Old May 31, 2011 | 10:26 PM
Razram55's Avatar
what tune am i running?
i tried hooking up the box to update it and it never brings anything up like "new hardware found". It just does the linked sound then the disconnected sound. Keeps doing it over and over again.
Old May 31, 2011 | 10:28 PM
Hmm... I had an issue on one computer maybe that's what's wrong with yours, you could also give quad a call they are very helpfull with this stuff
Sent from my DROIDX
Old Jun 19, 2011 | 01:09 PM
Razram55's Avatar
sent my box in, they sent me a new one. no more issues. Truck is a whole new animal.
Old Jun 19, 2011 | 02:03 PM
good to hear, they are pretty good guys to deal with!
Old Jun 20, 2011 | 08:57 PM
danielfoxracing's Avatar
i had the same thing sent my box in work fine for 90 days now it cuts out again i put a 165 airdog to never under 17 psi poops and cuts out on any after level 5 and buttons really dnt work even well to
KatiTrimmell
Jun 13, 2016 12:29 PM
dodge1998
Jun 13, 2016 12:25 PM
Oct 23, 2014 08:10 AM
MAC4232
Oct 16, 2014 04:22 PM
Oct 8, 2014 08:10 AM
