need help please
Old May 31, 2011 | 06:33 PM
dolla_hite's Avatar
Question need help please
so truck fell flat on its face when i was leaving work to go to lunch. just went a looked at codes and these are the ones that showed up.
P0216 Injection Timing Control Circuit Malfunction
P1693 Turbo Charge Control Circuit Malfunction
P1694 Turbo Charge Relief Circuit Malfunction
im going to go double check on the codes just to make sure. thanks for any help yall can give me
Old May 31, 2011 | 07:33 PM
outlaw1_gt's Avatar
Have you been having any hard starts or any other issues lately?
Old May 31, 2011 | 07:35 PM
dolla_hite's Avatar
no. went and got my new truck with it on saturday and didnt miss a lick
Old May 31, 2011 | 07:38 PM
turbo20psi's Avatar
I would check your fuel pump relay,its under the hood driver side.
Old May 31, 2011 | 07:45 PM
outlaw1_gt's Avatar
do you have a stock lift pump or aftermarket like an airdog or fass?
Old May 31, 2011 | 07:46 PM
dolla_hite's Avatar
if it was a fuel pump relay it wouldnt run right? cause it runs fine just has no power
stock but its putting out good pressure
Last edited by dolla_hite; May 31, 2011 at 07:46 PM. Reason: Automerged Doublepost
Old Jun 1, 2011 | 02:03 AM
banditsdiesel's Avatar
the 0216 is a timing malfunction code that is very general. it could be a large mixture of air in the fuel or could be the pump failing. also it could be something damaged in the pump, mine was throwing this code and we pulled the pump down to a broken delivery valve. the 1693 is a companion code from the jtec module. this is a code that basicaly says there is a code set and im not sure on the 1694 off the top of my head. it sounds like the pump could be failing to me...
Old Jun 1, 2011 | 02:33 AM
biged681985's Avatar
time for a new VP44 and lift pump. every time i have seen the p0216 its been bad. the p0216 is considered the death code. imo, i would put an airdog on the truck when you replace the IP to make sure the vp44 always has a good supply of fuel. me or any of the other sponsors here on db can get you a IP and a LP and a lot of the time when you buy them both you can get a lil better deal
Old Jun 1, 2011 | 06:59 PM
dolla_hite's Avatar
but if its the ip would it still run?
anybody else have any input for me?
Old Jun 2, 2011 | 09:01 AM
ntallent's Avatar
yes it will still run it just wont have the power it should because its not supplying enough fuel to the injectors
