Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
COOLANT LEAK, NEED HELP!
Old May 30, 2011 | 09:40 PM
cbsmoraine's Avatar
Question COOLANT LEAK, NEED HELP!
I have a coolant leak, found the leak, now i need to know where i can get a illistruated parts breakdown of the engine, so i can figure out the gasgut, or part i need. attached are pics of the leak.
Old May 31, 2011 | 08:23 AM
BriteWhiteRam's Avatar
possibly the waterpump
Old May 31, 2011 | 12:40 PM
cbsmoraine's Avatar
too far to the right (top view) to be the water pump. i'm fairly certain its a gasgut, but i need to know where i can find a parts illisration so i know which gasgut to get, unless its one of those things where i can put some "make a gasgut" on it and call it good.
Old Jun 1, 2011 | 04:28 AM
SgtKilroy's Avatar
Since that gasket would be under pressure, you probably want a solid one. You should be able to go to the dealership and get the correct gaskets. X2 on the water pump. Take the lower rad hose off and check for play in the impeller with a screwdriver. I think AllDataDIY.com might have an illustration, but otherwise I think you'd have to get a factory manual.
Old Jun 1, 2011 | 01:00 PM
Rttoys's Avatar
Originally Posted by cbsmoraine
too far to the right (top view) to be the water pump. .
You do know the water pump is not attached to the fan pully, correct? it is a bit to the dr side of the engine and internally gear driven. Kind of exactly where you made a circle in your first pic.
http://econtent.autozone.com:24991/z...52801cac68.gif
http://ww2.justanswer.com/uploads/Sp...weffwfewef.gif
Old Jun 1, 2011 | 04:58 PM
cbsmoraine's Avatar
Yep thats it, the "just answer" site is an exact pic of what i am looking at. called the dealership and they have the gasgut for $5.86........ looks like i have a long weekend ahead of me. Next question is, how much coolant will the entire system hold? im guessing somewhere around 3 gallons but if anyone has any better insight, please run it by me.
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
