trailer brakes fuel level
Old May 30, 2011 | 08:44 PM
csdiesel's Avatar
Default trailer brakes fuel level
On my 05 6.0l every now and then my trailer brake will light up and on the dash it will say trailer disconnected. and none of my trailers have trailer brakes. also my fuel level guage to day went from 3/4 to empty and said low fuel level, and i am certain it was at only half. if you guys have any ideas would be really helpfull. thanks. d
Old Jun 5, 2011 | 10:57 PM
PowerstrokeTech87's Avatar
check fuses first, ive replaced a few clusters in 05-07s for all kinds of issues. had 1 that the water in fuel light came on intermittently and i pulled the HMFC and replaced the filter and sensor took fuel samples from the tank and had no signs of water or other contamination in found it to be the cluster. could also try a simple reprogram for the cluster at a dealership.
Old Jun 6, 2011 | 08:56 PM
csdiesel's Avatar
thats a good idea. i got to go there any way, i just took a road trip blew out a hub cap, blew the plastic charged air cooler pipe, cracked the window, smashed 3 birds and a stray shopping cart
Old Jun 9, 2011 | 06:56 PM
csdiesel's Avatar
whats a hmfc again?
Old Jun 9, 2011 | 11:11 PM
horizontal mounted fuel conditioner (where the bottom fuel filter is)
Old Jun 10, 2011 | 10:42 PM
csdiesel's Avatar
thanks
Old Jun 13, 2011 | 05:36 AM
Cowboy Cadillac's Avatar
Sounds like a great weekend
as for the trailer... are you using a splitter or do you have the correct plug on the trailer. I have had issues with some of those.
Old Jun 13, 2011 | 11:20 PM
csdiesel's Avatar
i have a 7 pin in the bed and a 4 pin at the bumper. that light and alarm will come on pulling trailer and empty. i pulled the fuse for the controller. and it doesnt come on as often. im going to tear into the relays tomorrow. stupid 12 hr shifts at work.
Old Jun 14, 2011 | 05:07 AM
I here you on the 12hr. shifts If I were you I would definately check that 7 pin in the bed first. Seeing as it is the only one that should be connected to the built-in break controler. Surf the web and I bet you can find the propper wiring schematic for your truck or take it by the closest trailor sales shop and have them take a look
Old Jun 14, 2011 | 05:25 PM
csdiesel's Avatar
will do. this site is awsome. you guy provide the best info. thank you.
