u joints
Old May 29, 2011 | 03:00 PM
01cummins13's Avatar
Default u joints
well since its nice out and i had nothing to o today i decided why not start replacing the u joints on my truck, i started with the driveshaft. after i get it out, i find out my father had gotten rid of of vice to some kid who was collecting scrap. 5 hours later, its back in, but now i have a really loud squeek.
Old Jun 2, 2011 | 11:10 AM
justbuckner's Avatar
Just curious? Do you hear the high pitch squeak while driving and/or just when your slowing down and stopping. Two years ago I had a u joint go bad and the sound was a high pitch chirp and I would hear this while going through all the gears. The pitch would get louder as I increased speed and would go away when I'd be stopped.
Old Jun 2, 2011 | 11:31 AM
Farmboy 2.0's Avatar
Did you do all of them or just one? Any of the needles fall out?
Old Jun 2, 2011 | 11:53 AM
I wanted to replace all but only replaced the joint that failed. I have a skyjacker 4.5 lift on my truck and roll on 315 size tires. Do you think the lift kit causes the stock u joints to fail sooner? Lately I've been hearing a small chirp coming from the front end and hear this when I roll to a stop. Not sure if it's drive line or wheel bearings or brake issues? Any ideas would be most helpfull. Thanks
Old Jun 2, 2011 | 12:10 PM
The best thing to do when you do rear u joints is replace all of them to insure that they all stay tight because if one goes bad its gonna wear on the other ones. And a lift will add to the wear because of the change in angles of the driveline going to the pinion on the truck. Especially if you did not do a carrier bearing drop on the back IMO. And for the chirp for the front it could be the u joints, but I would check the knuckle u joints, and jack the front up and spin the front tires to see if the wheel bearings have some play or make a abnormal noise.
Old Jun 2, 2011 | 12:15 PM
my squeel went away after a few miles after replacing both u joints on the rear drive shaft. This weekend i will be doing the front drive shaft u joints, axle u joints, and ball joints. Im praying my wheel bearings are not bad because i do not have the funds to replace them.
Old Jun 2, 2011 | 12:32 PM
Would a reputable off road shop know to do this carrier bearing drop during kit installation?
I will check the knuckle joints. Looking or listening for anything in particular. Will let you know what I find. Thanks
Old Jun 2, 2011 | 12:38 PM
Alot depends on whose kit it is as well I think... I know bds does but some of the cheaper brands might not have a option for that. I would like to think they would but you never know. And with a gasser I think you could get away with it better than a big torquer diesel!
My truck is not even lifted but I have went through 9 sets of u joints in mine from heavy towing and what not
Last edited by Farmboy 2.0; Jun 2, 2011 at 12:38 PM. Reason: Automerged Doublepost
wildbill
Oct 2, 2015 01:56 AM
LawdawgSHPD
Aug 21, 2015 06:23 PM
CumminsCoalRoller24/7
Jul 5, 2015 06:30 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
