need help! please!
Old May 28, 2011 | 07:21 PM
jdbigblue12v's Avatar
Default need help! please!
i may have pinpointed myelectrical draw. the previous owner had the hood light wire unplugged form the light and i opened the hood and tryed it. the light is good and i thought to close the hood and see if the light stays on. the light stayed on when the hood fully latched. that why it is unplugged! is it possible a bad sensor could keep power sent to it and is killing my batteris? please respong im desperite for an answer!!!
Old May 28, 2011 | 08:34 PM
tower_ofpower's Avatar
If it was already unplugged and the
Draw was present then it isn't the hood light; if you plugged it back in and the draw developed than it's a possibility. Have you measured the amount of draw the truck has? (unhook the positive terminal and put an amp meter in series) pull fuses until your amp reading drops and you have then isolated which circuit is causing the draw.
Old May 28, 2011 | 11:39 PM
i havent yet found out the amount of draw yet but will tomorrow and it was already unplugged
Old May 29, 2011 | 01:34 AM
cumminskid92's Avatar
without the light it should have been an open circuit so it shouldnt draw and power... right?
Old May 29, 2011 | 09:59 AM
right; which is why i dont believe it was the hood light. do you have a brake controller? i know my truck sat pretty much all winter and the brake controller killed my battery. do you have anything aftermarket that is hooked to a constant hot? oh and the hood light switch is a mercury switch built into the light itself.
Old May 29, 2011 | 10:02 AM
ok im gonna go out in a few and try the test with the meter and pull fuses but no nothing after market except the p.o installed cab lights and theyre on a sepereate switch i was think false wiring on those to but gotta pull fuses.
Old May 29, 2011 | 11:52 PM
crazy clem's Avatar
this may be kinda stupid but my brake lights were staying on and and iwasnt noticing, also on afriends truck i found a dirty battery case that was conductive and draining the battery
Old May 30, 2011 | 02:01 AM
what do you mean dirty battery case? is it the mounting spot the plate on bottom? and i found that my cigarette lighter draws 8 volts so would i be able to just kkeep the fuse out all together??
Old May 30, 2011 | 07:25 PM
crazy clem's Avatar
it had a greasy type of film on it. I found it by using volt meter one lead to plastic case of battery one to ground , his read 9.5 volts to ground. was enough to kill battery .
Old May 31, 2011 | 07:04 AM
KD93's Avatar
Yes.
That's a ridiculously HUGE draw.
