help please ?s about 47rh
Old May 28, 2011 | 07:06 PM
joshwebb609's Avatar
Default help please ?s about 47rh
Hello i need to find out what i need to do to a 47rh to hold up to an hx55 a 215 pump with free mods and a set of 5x16 injectors I wanna pull it drag it!! Thanks for any input
Old May 29, 2011 | 07:57 AM
wizard's Avatar
Default trans build up
The weak links in the trans starts with the flexplate, use sfi hd, then converter I would use triple disk, hardened input shaft, good overhaul master kit with kolean steels, 6gear planet gearset, with hardend sun gear, billet accumalator pistons, high energy bands, and upgraded band apply rocker, good shift kit, and new hardend pump gears, deep pan, with high flow filter, this would be a good start!
Old May 29, 2011 | 07:21 PM
monster12valve's Avatar
hx55 gonna b a slow spooler
Old May 30, 2011 | 09:13 AM
Dang Sounds like a lot if parts but I know I gotta get them u wouldn't happen to know were to find parts like those for less than an arm n leg! And I'm using an hx55 because its what i got I'm waiting for a 16cfm housing so that should help! Please give me some advise!
Old May 30, 2011 | 08:33 PM
tower_ofpower's Avatar
Look up PATC transmissions. I got my upgrade parts for around $300... Granted your list of parts are more extensive than mine. No matter where you go a hardened/billet input shaft is around $800. Get an intermediate shaft too; use the output shaft as the weak link. They're easily replaced by yourself
Dudeman
Apr 5, 2015 10:28 PM
davidthomas
Mar 24, 2015 12:41 AM
02Stain
Feb 18, 2015 10:02 AM
rtbcoop
Dec 30, 2014 02:13 AM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
