Got a 03 2500 yesterday...
Is there anything that i need to replace off the bat with this guy like KDP or on fords 6.0 the egr and dpf or is it good completely stock
(haha) but seriously do i need to replace smething or leave the truck as is imma do an intake and exhaust guages and programmer anything else
Ditto on the filter, if you install an aftermarket lift pump, which I recommend sooner than later, it should come with a 4 or less micron filter. Make sure to get a pyrometer gauge when you install the programmer, if it does not already have one with the kit.
Check the front end (ujoints, balljoints, steering parts, wheel bearings), an aftermarket lift pump and filter will help, no one lubes the zerk fitting on the front driveshaft so check that and fill it up with grease (good luck finding it). That should be about it. Whenever I buy a vehicle I check and replace all the fluids making sure the engine doesn't have 90wt gear oil to cover up a leak or problem.
DirtyDiesel58
Jun 7, 2015 11:50 PM
