engine temp running high
Old May 27, 2011 | 07:01 PM
jlherrington's Avatar
Default engine temp running high
2001 dodge cummings 5.9 has quadzilla w/ adrenaline. My truck has been running good until i pulled my 24 ft 5th wheel camper up in the mountains and it started running hot, alot hotter than usual (215-220). I pulled over and let it idle and opened the hood and it cooled back down. I started back up again and i done it again, at 45 to 50 miles per hour up the hills...once i speed up it cooled back down...I have stock exhaust straight pipe and air dog fuel pump, and afe stage 2 air breather, but do i need a bigger exhaust or what could the problem be......
Old May 27, 2011 | 09:17 PM
95powersmoker's Avatar
Moved to the Cummins section for you...
Old May 27, 2011 | 09:22 PM
RAW's Avatar
RAW
I'd be looking at replacing the thermostat and checking the radiator for debris.
Old May 29, 2011 | 12:12 PM
Oil Igniter's Avatar
220 is about where the clutch fan locks up. dont be afraid of a little RPM while pulling also. Like RA said checking the rad and changing the thermo aint a bad idea, new coolant would not hurt either. In the hot summer pulling a boat up a big hill my rig will get to 220 but then the fan comes on hard and it cools down. I run mostly water in the system, about 4 parts water to 1 part antifreeze.
Old May 30, 2011 | 11:12 PM
Red_Rattler's Avatar
High Tech Redneck
I'm gonna bet the back side of the rad by the fan is plugged with oil residue from the blow by bottle... Clean it and problem solved.
burndiesel
10
Feb 7, 2023 01:15 AM
Jct
Jun 23, 2015 07:52 PM
JDurks2
16
Jun 7, 2015 08:57 PM
mesjr
May 18, 2015 05:16 PM
robbyS
Apr 16, 2015 02:22 PM
