PROGRAMMER ?
Old May 27, 2011 | 09:32 AM
Chad96Dodge's Avatar
Default PROGRAMMER ?
What and or is the best PROGRAMMER for a 96 5.9 12v cummins?
Old May 27, 2011 | 09:52 AM
Default Re: PROGRAMMER ?
No programmer for 12v's. Its all mechanical.
Luke
Old May 27, 2011 | 10:42 AM
cummins95's Avatar
snap-on
Farmboy 2.0's Avatar
Yeah the only programmer you can get is a TS look up controller or ATS Commander or co pilot. To make power with these trucks its all in the fuel plate, AFC housing, and Injectors and injection system parts
I was just informed by a friend of mine. Would you know anything about Bully Dog WatchDog Economy Monitor? for gauges insted of the piller.
Old May 27, 2011 | 10:43 AM
That wont give you the readings you need. Your truck doesent have a ecm for it to give you the readings on
Old May 27, 2011 | 10:50 AM
So what does the ATS Commander do? do I need a Exhaust Brake?
I looked it up and the info I got was COMMANDER - Controls Trans TCC & Exhaust Brake.
Disables Issue w/Factory TCC Engaging Too Early @ Low Speed?
So I would be better off just getting the piller with individual gauges?
Last edited by Chad96Dodge; May 27, 2011 at 10:50 AM. Reason: Automerged Doublepost
Old May 27, 2011 | 10:52 AM
12vNick's Avatar
Ats trans commander will allow you to chose the speed at which your tq locks up (as low as 18 mph) and will work a lot like an exhaust brake or also in conjunction with an exhaust brake.
Old May 27, 2011 | 11:13 AM
daveO's Avatar
Yeah, the only way to get the readings you're after is a pillar with gauges. Pyro, boost, and trans temp if it's an automatic.
JPatt
Jul 29, 2015 03:25 PM
ForrestB
8
Mar 4, 2015 08:53 AM
cowpolk
Wanted To Buy (WTB) - Used
Jan 25, 2015 07:31 AM
aoutlaw95
9
Jan 5, 2015 07:21 PM
