Running problem with 6.5 diesel
Old May 26, 2011 | 07:54 PM
logan80's Avatar
Default Running problem with 6.5 diesel
I have a 95 k1500 4x4 with a 6.5 turbo diesel it has a little over 79,000 miles on it..The problem im haveing with it is it will run for only 8 -12 seconds and it only has throttle responce when first started for a couple seconds then idles for another 10 seconds and dies.It had DTC 54 which is a internal fuel fault in the PCM so I replaced it with a new GM one..Also replaced the fuel filter ,Lift pump and the sending unit ..And the truck still has the same problem..I hope some one has some kinda idea!! Thanks for any kinda help!
Old May 27, 2011 | 10:38 AM
12vNick's Avatar
May be worth a call to Heaths Diesel those guys are definitely the 6.5 gurus.
Old May 27, 2011 | 04:56 PM
Crazy's Avatar
check all the ground to be tight and clean the computer ground at the back right side of intake should be 2 or 3 wires there and there are 2 ground strap right there under the A/C Dryer on the firewall one goes to back head the other to the frame make sure they in good shape , clean and tight and there ground on top IP for PMD check it and then there ground at the right battery on the fender check it then clear all codes see if it come back
Old May 27, 2011 | 07:11 PM
Boiler01's Avatar
You might also check for cracks in fuel lines and hoses, even cracks/holes in vacuum lines can cause running problems.
burndiesel
10
Feb 7, 2023 01:15 AM
Easton18t
Jul 30, 2015 02:06 PM
JamesL91
Mar 15, 2015 06:11 PM
ssmith.77
Jan 11, 2015 02:03 PM
Snoobly
Dec 11, 2014 11:59 AM
