01 questions
Old May 25, 2011 | 11:47 PM
02 cummins in's Avatar
Default 01 questions
Just went and bought a 01 and I don't really kno what the pyro is suppose to read its normally around 8 reads up to 15 and the trans might be unhooked cause it don't read over 140. And the trans kicks when I put it in drive. Is it goin out or easy fix?
Old May 26, 2011 | 08:02 AM
turbo20psi's Avatar
8 would be 800 degrees before turbo if that is were the pyro is tappet in the manifold.That sounds right.What is done to the truck? 140 degrees for the trans normal it depends were the temp probe is (in the pan,on the supply line to the cooler).
" Kicks "do you mean luch forward when you put it in Drive?
Old May 26, 2011 | 12:31 PM
1AMatt's Avatar
Site Sponsor - 1aauto
1500 seems kinda high on egts depending on whats done to the motor. But 140 for the trans is a perfectly normal operating temp
Old May 26, 2011 | 07:40 PM
Yea when I put it into drive it lunges forward and I'm not 100 percent sure where it tapped into the trans just yet I was wondering if the u joint might be making it kick what do you think
Old May 27, 2011 | 03:15 AM
banditsdiesel's Avatar
sounds like its just got a really tight tc in it. most performance tc or trans will lunge when put in gear it comes from higher line pressures and lower stall speeds in the tc. i wouldnt worry unless it starts making noises or slipping.
Old May 27, 2011 | 04:28 AM
Well glad to hear that its not messing up thanks for all the help but is there anyway from knowing if its build by looking at it because I bought it from a dealer and they had no clue.
Old May 27, 2011 | 07:46 PM
turbo20psi's Avatar
There is a rubber plug on the bottom of the transmission were the TQ is. Remove that and see if there is a billet converter. Another way is to do a line pressure test to see if there is a aftermarket VB.
Mar 20, 2015 08:20 AM
VanGuy
Feb 3, 2015 12:19 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
