why does my truck go into high idle
Old May 25, 2011 | 02:45 PM
Natedawg!'s Avatar
Default why does my truck go into high idle
my truck will high idle every time i get off the highway... it idles at 1200 and wont come down. i have to pull over and turn the truck off for 30 secs then turn it back on and it will be fine.... sometimes while sitting idling it will randomly idle up.... and info or help? going to drive me insane here soon! Ive messed with the apps all that i can? any suggestions?
Old May 25, 2011 | 10:06 PM
RAW's Avatar
RAW
Is this a comment or statement? APPS reset and adjustment have been done?
What is a "power edge 5 stage chip"? Is it a Edge Juice With Attitude? If so, bring up throttle position as one of your monitored items and watch it when the issue happens.
Does a quick tap of the throttle do anything while idled up?
Old May 26, 2011 | 01:12 PM
Natedawg!'s Avatar
Yes i have adjusted and calibrated the apps... As far as the edge its the edge comp.. When the truck is idled up and i blip the throttle it revs up but the comes back down to 1100-1200.. Its been doing it ever since i had the head gasket done..
Old May 27, 2011 | 03:22 AM
banditsdiesel's Avatar
do you know if anyone may have stuck a smarty or some other type of programmer in it that could have had some type of high idle software that alters the factory ecm tune. on the other side the coolant temp sensor could possibly be misreading causing it not to show the ecm proper temp cause the high idle control is supposed to not kick in after 140 degrees on most softwares.
Old May 27, 2011 | 03:14 PM
Natedawg!'s Avatar
Not that i know of about the smarty... I havent used a smarty on since ive had it... How would i go about seeing if its the coolant temp? My gauge seems to be working it slowly goes to 190 and stays
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
robbyS
13
Dec 20, 2014 04:25 PM
Oct 14, 2014 08:40 AM
