12 valve build
Old May 24, 2011 | 07:53 PM
7.3 Cowboy's Avatar
Default 12 valve build
Im buyin a 12 vavle and am gonna build it up some but need some advice here is what i have so far. Let me know what y'all think.
150-200 Horse injectors/5-.014 or 5-.016
181/191/full cut delivery valves
3 piece exhaut manifold
O-ring/fire ring head gasket
head studs/bolts
66/71/14 turbo: II Super Phat Shaft 66
4gsk
hd valve springs and keeper
overflow vavle
Old May 24, 2011 | 08:05 PM
1SlowCTD's Avatar
Don't forget to mention that it already has a FASS and a Dual Disc.
Old May 24, 2011 | 09:22 PM
7.3 Cowboy's Avatar
Thanks for that i never thought of that
ALSO what is all involved with fire or oringing a head ?
Old May 25, 2011 | 05:51 AM
12valvetater's Avatar
Fire rings have a grove cut in the head and block. The fire ring is cut out of the stock head gasket, and another one is set in the two groves. Fire rings unless done perfectly don't like heat cycles. O-rings can be installed in the head, the block, or both. A groove is cut and a stainless wire is installed. The factory headgasket is run with o-rings. O-rings are better suited for street use, and will be all you will ever need.
Old May 25, 2011 | 07:35 PM
7.3 Cowboy's Avatar
So I go with the o ring then.
Can you stud one of these in the truck?
Old May 25, 2011 | 07:49 PM
daveO's Avatar
Yeah, you can. You put the head on first, and then thread the studs in, just like you would do with the bolts.
Old May 26, 2011 | 01:40 AM
BRE's Avatar
BRE
First off, your signature is ghey!
Now, what are you going to do with the truck? DD, sled, drag... ?? Then ill give my $.02
Old May 28, 2011 | 05:12 PM
7.3 Cowboy's Avatar
dd trailer puller mostly
Old May 30, 2011 | 09:43 PM
BRE's Avatar
BRE
Well that whole combo for what your doing doesnt make since to me.
Old May 31, 2011 | 09:45 PM
7.3 Cowboy's Avatar
why doesnt it?
